So here is the deal, I am running 2 internet connections right now, because I am in Australia its incredibly hard to get gigabit and I need to get a business plan. But however the ping/latency on the gigabit connection is horrible at around 50/60 ms. But however on the other connection I am getting a solid 2-20 ping. But the upload speed on the low latency connection is not nearly good enough to stream. I have a spare PC but it is annoying to setup and I dont have the right equipment. I was thinking if I connected to one via Ethernet and the other via Wireless, so I could stream via Gigabit and play on the low latency. I did a bit of research but it included  expired links ect. Is this possible and if so, how???
Cheers Oliver
idk tbh
https://linustechtips.com/topic/1058355-streaming-on-a-separate-connection/
You just pop into OBS-settings and choose which connection you want it to use.
27 minutes ago, schwellmo92 said:
What're you streaming that requires gigabit?
OP didn't say that they need gigabit for streaming, they said the connection with lower ping doesn't have enough upload-bandwidth for streaming.
There's plenty of lower level plans, and majority of Australian home internet connections can actually support streaming. I was just curious what he's actually doing as usually you stream at only a couple mbit.
It doesnt require gigabit. I would just rather stream on the gigabit connection and not have it slow down my game. The upload speed on the better latency connection has only a couple of mbps up.
idk tbh
