Most Quiet Cooler can fit NZXT S340
LanaDelRey
Hi,
I need a really quiet cooler for my system. I own Z370 Mobo w/ 8600K. Runinng on 4.8Ghz/1.35V.
Which cooler is best for me? Can fit S340, can handle 8600K 4.8 ghz and quiet.
Thanks for answers. Sorry for grammar mistakes.
Dark Rock 4?
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
1 minute ago, PopsicleHustler said:
Dark Rock 4?
Dark rock 4 (200W TDP handle) is : 80 $ cost
FSP Windale 6 (240W TDP handle) is : 55 $ cost
Do you think DR4 is worth to buy?
1 minute ago, LukeSavenije said:
nhd15?
Dimensions w/ fan not ok with s340
i think you should be fine if you lower the fan a little
Yes, even without the fans it's still too tall.
The NH D15S will work though.
Also the new NH U12A will work.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
Whatever i picked the Dark Rock Pro 4.
My case clearence 161MM and the cooler itself 162MM, i wish it fits.
Likely will be too tall.
it should, and you can always lower the fans anyways
Ankerson think again, u'll be wrong:
Quote "I was able to fit a Dark Rock Pro 4 into my S340 Elite case. It is like 1-2 mm from the glass, but doesn't touch it. This is on a socket 1155 build."
Quote "I was curious cause the clearance listed on the s340 elite is 161mm while the DRP3 is 163mm. But it fit no problem,"
Image:
for 1mm it normally doesn't matter
The NH-D15 and NH-D15S heatsinks are the same height but the NH-D15S's listed height is with the fan lowered.
The DR4 is quieter but you should probably get a better performing cooler for the price.
Where are you shopping / located? What ram are you using?
I can shop Worldwide, no problem with shopping.
I'm usin' Crucial's Sport LT rams, they are Low Profile so no issue with ram height.
DRP4 is my pick for most quiet cooler, that 250W TDP is awesome.
1-2mm doesn't really matter when you're trying to mount the cooler.
If my answer got you to your solution make sure to 'Mark Resolved!
( / . _ . / )
Manufacture stated TDP is almost completely useless. There's no standard way of testing.  Look at independent cooling benchmarks for how a cooler preforms.
Please be more specific. Most shops don't ship worldwide.
I ordered DRP 4 already :) I'll delid my cpu soon.
I have used a couple of them and the Dark Rock 4 is a great CPU cooler, it's powerful and quiet.
Thanks for all advices.
I delidded my cpu and installed DRP 4 now. This cooler is dead silence, it's awesome.
Congratulations on your new cooler and your successful delid!  Well done!
Well that's not true... You're shopping in the wrong places clearly. IE, 'Murica.
