10 minutes ago, NickToye said:
Right, sorry not used tags like this before, I don't know who to tag.
This look like what I would need.  https://www.corsair.com/uk/en/Categories/Products/CORSAIR-LINK/Commander-PRO-—-iCUE-RGB-Lighting-and-Fan-Controller/p/CL-9011110-WW
I believe so yes.
Dont worry about all the tags, not every vendor has a representative on this site, but it just so happens Corsair does.
2 minutes ago, NickToye said:
Is there a primer on tags?
By primer, do you mean a list of Industry Affiliates on the forum?
At one point there was but it was removed.
You are correct, the Commander Pro would replace your built-in fan controller, and provide LED and fan speed control through the iCUE software.  The Commander Pro will connect to the USB 2.0 header on the motherboard, and a SATA power connector from your PSU.  Let me know if you have additional questions, and I can help you out.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
No that's great. Actually I do have a Corsair product issue, but its with headsets, so I will raise a different post.
