My monitor is acting weird?
So my other monitor is quite old(it's not 16:9, 1080p monitor, it's that kind of old) meaning i  am using a VGA to HDMI adapter to hook it up to my rtx 2070 graphics card. When ever i plug in the monitor to the GPU the monitor shows the display on for about 2 seconds then goes completely black.
Probably can't hold charge for some reason, try turning it off and back on a great number of times
I'm not gonna lie, if I had a 2070 and was forced to use a VGA to HDMI adapter I'd be looking at new monitors, which I think you should do. Might not be worth to troubleshoot a display like that
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
yeah ik but i got it for free from my work and i want it for just discord on the side and use my good monitor for games
this also worked
(edit: nvm it didn't)
