Im looking to get a prebuilt for $650 max, any suggestions? color doesnt matter it just needs to run games well
Ryzen 5 1600x | Asus ROG Strix B350-f gaming | 16 GB Trident Z RGB RAM | Asus ROG Strix 1080 Gaming X | Hyper 212 Evo | 650 W 80+ Gold | 500GB 860 evo | 500 GB WD Blue HDD | Phanteks Enthoo Pro M Tempered glass.
https://linustechtips.com/topic/1051711-prebuilt-help/
Why a prebuilt?
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454869
-Moved to New Builds and Planning-
You'd get better performance for your dollar if you built one yourself instead of buying a prebuilt.
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454892
29 minutes ago, Slottr said:
Why a prebuilt?
Sometimes people just dont have the spare time, knowledge to build themselves, or just don't want to deal with the problems that can arise, for example my next computer will be built by the company i'm buying from just because I dont really want to build it myself
What area of the planet do you live in and does the $650 include shipping cost or are you looking at local buissness that you can pick up from (Will need to know the places in your area that you could pick up from)
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454913
You contradicted your argument
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454916
Its for a friend, he needs a computer and since I have only built computers im not knowledgable in the prebuilt world eexceept that at this cheap its not easy to get better prformance for the same price
Im in the usa
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454918
Im in the usa
Why don't you build a computer for them? You'll save a significant amount of money
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454924
16 minutes ago, Connor McG said:
Prove it...
Try finding that 1:1 from any SI at the same price.
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454936
?? as in paying for someone to build it? it is a bit expensive to do that especially when the budget is $650
The company i will probably use has this
3 minutes ago, Connor McG said:
Prove it...
Just found this on newegg and didn't think the price was that bad for something like this (though im australian and things like this easily set you back over $1000)
https://www.newegg.com/Product/Product.aspx?Item=9SIA77G5N88891
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454937
$699 for this with a 1600 and 3gb 1060 - https://www.newegg.com/Product/Product.aspx?item=9SIA08C5YY4206  -> also has 16GB ram
your using a 580, not many places will sell them especially inside of a prebuilt (Australian Knowledge)
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454945
Or for 650 you can get a 2600 and an 8GB RX 580?
That system will cost more and performs worse? I don't see your point
Also the ram is 2400, it will slow down the processor significantly
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454951
the 1600 isnt that much worse than the 2600
the ram speed won't offer that significant of a difference in gaming (Content creation is different), if your building yeah go the faster one as there isnt much of a price difference between 3000 and 2400
also saves the hastle of building it for his friend and if the friend lives in a different area to him (as i have a few friends across the world) the second shipping cost to get it there. yes i understand that you will get a bit better performance from building yourself but the question was - i'm looking to get a prebuilt for $650 max, any suggestions?
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454962
Yes it will, Ryzen's architecture depends on ram speed to perform well. The way it handles bandwidth is weird.
OP didnt mention this detail in any fashion so I am assuming their friend is local
a LOT better performance
Used i7 Dell optiplex and drop in a GPU.
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12454968
Oh yes it will, Ryzen CPU loves nothing more than fast RAM. I mean yeah, you can overclock the RAM, but I would rather do it on a better B450 board than the A320
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12455028
3GB 1060 = RX 570.
https://www.newegg.com/Product/Product.aspx?Item=1VK-005B-000E1&Description=gaming pc&cm_re=gaming_pc-_-1VK-005B-000E1-_-Product
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12455071
I really dont wanna go with ryzen because its pretty inconsistent in performance from my experience, doesnt OC well, and doesnt run well with games
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457426
Where did you see this?
Ryzen is a fantastic option for people a budget, or even people not on a budget.
I've been running a 1700 in my system for two years now and performance has been pretty consistent, also got a decent OC on it
You won't be able to get a decent system from intel on your budget unless you buy used
Btw, make sure to quote when you reply so people get notified!
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457861
im running a 1600x, I cant overclock a single bit, in some games like arma ryzen performs half as weell as intel
same with squad
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457870
same with squad
I think you have some separate issues, have the same motherboard as you.
Should definitely look into that.
Though regarding your friends PC, a 2600 is the way to go.
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457872
others have the same problem
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457875
How so?
What specifically are you facing?
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457881
games dont perform as well on ryzen as they do on intel, ryzen requires better ram
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457885
There's a few notes to make on this subject:
1- Yes, Ryzen processors won't beat out a say 8600k because of their single core performance. HOWEVER- this should not turn you off from looking at Ryzen. Their chips are still GREATLY equipped for games, and for a highly discounted price compared to an Intel equivalent
2- Yes Ryzen requires faster ram, the way it handles memory bandwidth is different from Intels, but even on Intel, having faster memory will subject a difference in performance. Besides, the price to go from 2400->3000 is fairly minimal. You shouldnt be getting anything lower than 2666 in the first place
If you want to get your friend an Intel based system, they will have to do one of two things:
- Sacrifice graphics performance to equate for the processor cost
or
-Buy used and get a system that is within budget, then throw in a graphics card if it doesn't have an adequate one already
So yes Intel has stronger chips for gaming, but that fact alone shouldnt make you turn away from Ryzen, it's a fantastic platform and offers great performance to people on a budget, such as your friend
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12457893
hes going to be strictly playing games on it
if it was an all around computer, then yes, ryzen
https://linustechtips.com/topic/1051711-prebuilt-help/#findComment-12464589
