144hz stuck on 120hz
P2g
Go to solution Solved by Aimi,
You might need to use Displayport.
Hello.
I just bought a new monitor Acer XF240H 144hz, when I turned my PC on and went to change the hz, it was already on 120hz and there are no other choices.
I just HDMI cable and my drivers are up to date.
Well im dumb.
Thanks :D
their website says 120hz max for HDMI, you need displayport as stated above.
2 minutes ago, P2g said:
Well im dumb.
Thanks :D
Nah you're not, common mistake
Quote or Tag people so they know that you've replied.
