120mm 2000 RPM fans longevity and durability?
Solved by Jurrunio,
27 minutes ago, _Hustler_One_ said:The LNA = Low Noise Adaptor, this short cable/adaptor usually is being included in Noctua's coolers package, not in individual fan package. The way it work is only reducing the RPM by some %, not reducing noise while it still run at rated max speed, and I think it's useless because we can play with fan curve instead..
19 minutes ago, kingknightrider said:Though using fan controllers?
That is something I would like to be avoiding in this new build...
No you can hook them directly to the molex connector, just like how the sickels are
