What switches are these
Xereth
I’ve been looking and I can’t figure out what the switches are on my keyboard do any of you know. Thanks in advance
Cherry MX Blue switches
Omron
1 minute ago, Joelw2003 said:
nope, Omron
They don’t look like omron
I didn't think cherry has the thing around the stems. My omron ones in my keyboard from the 45$ round up look like that. Anyway if the op looks at the top he might be able to see a name like khail or omron or something
Looks like the design Kailh Box switches use, but I don't doubt it's a Chinese manufacturer copying being inspired by the design of those switches.
Check around the stem (blue part) of the switch; usually the manufacturer's name is branded on the switch itself.
They are outemu switches
