Mini Deep Freezer water cooling
Hey linus and pals i was thinking you should try using a mini deep freezer to cool a custom loop. Not only will it keep your pc cool but it will serve as a great place to store your beverages and and hot pockets lol. Looking forward to hear what your thoughts are about this idea so plz let me know.
I believe he did something similar to that, cutting to the point he stuck a computer into a refrigerator and it didn't work since it wasn't designed to do that.
Main Computer :
CPU:
Ryzen 5 2600x (STOCK)
GPU: Evga GTX 1060 3gb (STOCK)
RAM: Geil Potenza 8gb
SSD/HDD: WD green 120gb SSD/ 1 TB HDD
MOBO: Asus x470-Plus Gaming
PSU: Evga SuperNova 650 P2
Cooling: Antec 120mm liquid cooler
There have been other YT’ers out there having tried similar or same things already.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Thats what gave me the idea you can drill some holes in the top or the side and run tubing into it with a rez
But it has been done already..
honestly, most cooling solutions have been tried before on youtube. Most failed, or literally makes no difference whatsoever, You could come up with an idea and do it yourself, post your data.
It's unlikely you could make something that would be revolutionary unless you are pretty smart to invent something that this.
Main Computer :
CPU:
compressor isn't made to work constantly.
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
