Why do you care?
I'd be boasting about that
https://linustechtips.com/topic/1048262-limit-wifi-range/#findComment-12426264
You can't really without making the wifi in your own home worse. Use a password or change the name to something super generic if it bothers you for some reason.
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
https://linustechtips.com/topic/1048262-limit-wifi-range/#findComment-12426308
You can disable ssid broadcasting if you want nobody to see your wifi.
https://linustechtips.com/topic/1048262-limit-wifi-range/#findComment-12426344
