So I decided to upgrade my old prebuilt pc. Just adding a graphics card but the psu didn’t have any pci 6+2 connectors so a new psu as well.
I get the parts install everything go to turn it on and nothing. No beeps no lights nothing.
After an hour or 2 of checking connections and as such I decide to check that I’ve not fried something so reinstall the old psu and everything works fine.
I do a paper clip test on the new psu and it works fine. So the psu is not completely dead. So I test a few other things that I can think.
if I connect just the 24 pin connector of the old psu to my motherboard and hit the power button I get fans and a power light. If I do the same thing with the new psu I get nothing.
System specs im dealing with
mother board: msi a68hm grenade
cpu: a10 7870k
new psu: gigabyte p650b
is there anything obvious that I’m missing.
Many help would be absolutely amazing.
https://linustechtips.com/topic/1046618-new-power-supply-issues/
the switch at the back of the new PSU isn't turned on?
Desktop benching:
There are 2 Power connections on the MB.
1x 24 pin and 1x 4 pin
Both need to plugged in.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
I know. When I first set the new psu up I connected all power to everything including HDd, optical drive, fans etc. The only reason I mentioned just plugging in the 24 pin plug is because I found it unusual that the old psu would power on with just that plugged in but the new one doesn’t.
cpu: a10 7870k
Any help would be absolutely amazing.
As @Ankerson said, you need both the motherboard 24pin and the CPU 4pin power plugged in. The system won't work if only the 24pin is connected. Needs both motherboard and CPU power.
Which model PSUs are you using? (Old one and new one)
  Reveal hidden contents
Again I do know that and have tried with both in and get nothing. I only tried with the 24 pin connector to test the psu out to see if it would power on at all.
The old old psu is a system builder generic 500w
the new one is a gigabyte p650b
