Current specs
cpu: i7 7700k (I don’t think this needs upgrading)
CPU cooler: Corsair h100i v2
Motherboard: MSI z170a pro
memory: 32 gb DDR4 3000mhz Corsair vengence
storage: 1tb SATA ssd, 1tb HDD, 2tb hdd
Graphics Card: gtx 1060 3gb (I assume this needs to be upgraded)
psu and case I don’t plan on changing but the case is atx mid tower and a fully modular psu by Corsair.
Upgrade Budget: $1000
i plan on using premiere pro almost daily, and then photoshop sometimes. I want decently fast rendering times. But I’m mostly concerned about playback speeds while editing. I’m wondering what the i should upgrade or if not an upgrade a new pc. Just want general tips for what to get in my situation.
https://linustechtips.com/topic/1045769-content-creation-pc-upgrade-help/
On 3/18/2019 at 1:07 PM, Puffing said:
-snip-
YOu have a solid system, and I hope you did raise the multi and OC that vieo card.  At stock speeds my OCed 7 year old will hang with it.. OCing is a must ijn this world.. theres a reason why intel invented it.  Get your GPU to 4.6 or 4.8Ghz  Your RAM kit is nice that will suffice.  You have a SSD which is a must.  Only problem I see here the 1060 3GB.  That will bottleneck the system.  Your CPU is just fine OCed.   But ya you would be better off with a 2060 or 1660Ti.  VRAM matters when you do content creation Premiere etc..
SO ya 3GB is a big bottleneck.  I would go with a 1070 or a 2070 and your render times will decrease as well.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
1 minute ago, Puffing said:
Ok thanks what should OC the cpu to?
Ok so I take it you have knowledge of OCing ?  Simply we work with 3 thinks.  You should have a turbo option.  Im not sure what Mhz that gets you to.  To do it manually, you just need 3 settings to worry about.  CPU multiplier.CPU voltage and Load Line Calibration, also knowns as LLC.  First try just turning on Turbo, then ventually you can raise the multipler.  I would aim for 4.4Ghz if your using cummy CPU cooler.  Im not quiete sure about your CPU and what voltage it needs for a 4.4Ghz overlcock.  If you have sufficient cooling then take her to 4.Ghz just by raisng the mutli ,,,, then put your CPU voltage to 1.30v and see what happens.  If it boots up fine,, then I would start to lower the voltage so find the sweet spot.  We don't know how much voltage your 7700k needs every chip is different.  For now try a free overclock.  Set her to 4.2Ghz and turn on Turbo in BIOS and lets see what happens.
Spend the $500 on a RTX 2070 and you'll be good...
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I am honestly not to informed about OCing, I planned on it but never really needed it, is there a YouTube video to watch or a place on their forum. I have a goos cooler: h100i v2. Thx in advance.
Your cooling will allow you to get a nice OC on that chip.  Let me find a video for you cuz sometimes text isn't enough.  Here you go Overclocking 7700k
TBH Thats still Perfectly fine. Getting a 8700k or 9900k will improve it A bit but honestly? Your going to just be fine with what you have. Dont upgrade unless you are making money off content.
4 hours ago, Puffing said:
What about a 2060?
Go for a 1660Ti or Vega 56 instead over the 2060. Much better value.
Full Specs
Helios EVO (Main):
Delta - Laptop
Ok but I can’t upgrade my cpu because im
on a Skylake board.
Great bones in that system, I'd only upgrade the GPU if you want better 1080p gaming.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Don't repost...
Full Specs
Helios EVO (Main):
Delta - Laptop
on a Skylake board.
You can get a 8700k and z370 obv would have to gotten. But i dont think its worth it unless you are actually making $$$ from it. Otherwise stick to what you got and make better and more consistent content
ram is more than enough
psu is fin
storage is good
cooler should be fine
your current mobo is kinda sketch bu should be okay
upgrade your gpu and maybe you mobo and cpu
Type Item Price
CPU AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor $248.89 @ OutletPC
Motherboard Gigabyte - B450 AORUS ELITE ATX AM4 Motherboard $113.98 @ Newegg
Video Card EVGA - GeForce RTX 2070 8 GB Black Video Card $489.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $852.86
  Generated by PCPartPicker 2019-03-19 15:50 EDT-0400
can get a 2080 is you want to spend more money
changing to ryzen since ryzen generally has better value for things like content creation but if you want intel you could also go that way
Get a better GPU, the rest of the system is fine.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
I'd get a 2060, and the rest is fine.
If you're looking for a better CPU go for a 8700K, 9900K (not recommended, needs a very good cooler and an expensive motherboard), Ryzen 7 or i7/i9 X299 CPU (such as the 7800X)
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
Haven't read other comments yet but upgrading is a huge waste IMO. I would only get a new GPU and that is it. If you render with Adobe premier, for example, a more powerful GPU would help thanks to Cuda acceleration, so a used 1080 Ti would be perfect, otherwise, your CPU is just fine. I still use my 6700k all the time for content creation and CAD modeling.
I guarantee you would barely notice a CPU upgrade, just OC the snot out of your 7700k.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
