So I just built my first gaming PC March 15th and all was going well and I never would've noticed anything was off until a friend of mine who had an RX 570 had told me my CS:GO framerate was absolute trash on an RX 580. I started looking around and trying to figure out the issue and tried a few things such as removing MSI Afterburner which changed nothing. I went into the BIOS and factory reset it in case I might've bumped something during setup which changed nothing. When using NZXT Cams to see my cpu/gpu temps and usage my cpu would sit at around 1.8ghz with a temp of 41 degrees. With these numbers I'm only achieving 90fps in game and should be getting at least double that number. Another example is in Rainbow Six Siege I sit at 2.2ghz in menu at 44 degrees and at 3.2ghz in a match with only 51 degrees and get about 95fps. I'd love any and all help and recommendations for this so that I can get back to playing more reasonably and for csgo especially, to be able to utilize what I had paid for instead of like the old 2gb vram like my old build which performed like how it currently is. Full build list below.
CPU: AMD Ryzen 5 2600
Motherboard: Gigabyte B450 Aorus Pro Wifi
RAM: G.Skill Ripjaw V 16gb 3000mhz
GPU: XFX Rx 580 Black Core Edition
Storage: WD 1tb M.2 SSD
PSU: 750w Rosewill 80+ Gold Modular
https://linustechtips.com/topic/1045286-ryzen-5-2600-help-please/
Seems like you’re CPU isn’t boosting its clocks nearly enough.
But thats a motherbaord issue. Check your BIOS setttings and make sure you’re letting the chip get the power it wants. Could be VRM related too, make sure the motherbaord has adequate airflow.
1.8-2.2GHz in games is too low. You should be hitting 3.75GHz average across all cores with an R5 2600.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
is the cpu cooler mounted properly
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
