I'm having a hard time deciding on if i should get a  AORUS X Hybrid  or the lightning Z card. Gbyte card has better tempts but is on a 366W bios and the lightning is on a 380w bios which i also see people getting from 60~ to 84~C. is there a clear winner between these 2? can the Gigabyte card use another vbios to get 380W or higher since i can't find any specific vbios for it other than to the windforce?  all in all i see both cards get to around 2Ghz is there really much performance difference between them, should i just go for what gets the coolest temps and is the quietest at this point ?
source: https://www.overclock.net/forum/69-nvidia/1706276-official-nvidia-rtx-2080-ti-owner-s-club.html
AMD Ryzen 9950X3D [x2 360 Rad EKWB] | Asus Extreme x670E | RTX STRIX 5090 OC@3GHz [Alpha Block] | Corsair HX1500i | G.Skill Neo CL30 6000MHz (2x32GB) | Samsung 9100PRO 8TB Gen5 + MP700 2TB Gen5 + 980/950 Pro 1TB M.2 | x6 85PRO 512GB | NAS@10Gbit/s 4x 24TB Seagate Exo Raid 10 (2x 1TB raid 1 NVME Cache) - 4x 1TB NVMe Raid 0 + Backblaze | Lian-Li o11D XL | Main Screen: Samsung OLED G9 | AUX: LG IPS7 27" (x2) LG CX 55" G-Sync | 10Gbit/s ISP connection | Copyright©1996-2026 Teletha All rights reserved. ®
https://linustechtips.com/topic/1043065-2080ti-purchase-help/
3 minutes ago, RaW D Coy said:
 all in all i see both cards get to around 2Ghz is there really much performance difference between them?
If they are very similar in performance, then the gigabyte one is likely more efficient since it remains cooler. Therefore, that's likely better. However, fan noise is also a factor. What are the prices for each of these cards for you?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380596
They are at the same price
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380601
Well, then I think the only factor is case real estate. The hybrid card having a radiator means you have to consider mounting, but if that doesn't matter to you then it's likely the better buy. Two large fans vs 3 small fans is probably quieter.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380603
This is more of a case, do I want AiO or air cooling?
I think I'd get the Gigabyte, that card looks pretty dope even if I have always only used air cooling. If I'd buy a 2080 Ti  I would probably go with the water blocked one and make the hassle to water cool it properly, that card is insane beautiful.
Mount it on sideways, for extra PCMR glory, should overclock really well considering nowadays power limits are as meaning as temperatures, Turbo Boost 3.0 only cares about temperatures and overclocks are really depended on it with nvidia since Pascal.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380620
Both really arent worth it, the price is insane and honestly, if you get a regular one triple fan, youll get 98% of the performance.
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380646
Makes me upset I bought my EVGA 2080 ti when I see this one
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380658
maybe ill just get the trio and get the 404w bios
https://www.techpowerup.com/vgabios/205495/205495
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380678
You could do it as the Trio is 98% of the Lightning except for the power mods, but honestly just be careful with certain bios. Just makes sure its legit :D
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380683
a hybrid is almost guaranteed to have lower temps than an air cooler, and with boost 3.0 thats worth more than a silicon lottery dice roll on the lightning z (watch jay's video)
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1043065-2080ti-purchase-help/#findComment-12380794
