How is Dezel(TheIntern) not an admin?
Go to solution Solved by Guest,
He does not require access to the data and abilities that admins have.
Hi guys!
Just saw this post posted by user: Dezeltheintern and i clicked on his page and he was not an admin or what so ever. Is this the real one or what? And if he is THE Dezel the intern why isn't he even a moderator?
Woops tipo in the title, fixed it!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/104151-how-is-dezeltheintern-not-an-admin/
Maybe he wont spend time on the forum
Doesnt need to be if he isnt on the forum much.
Listen if you care.
So he doesn't get contacted with people's problems.  He doesn't do forum management stuff.
I can understand that but why doesn't his profile say something like staff member?
he uses ad block?
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
he uses ad block?
I think that is it!
Same reason I am not.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
might not manage but I'm sure he reads some feedback on video quality. but eh i guess he doesn't have to be a mod if he doesn't want to.
The Syndicate
I think Linus might have mentioned once that Dezel said he didn't want to be one.
He probably just doesn't have time to be on the forums with all the work he has to do.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
