is Corsair link worth it? (Power supply)
Tmh85
So I'm looking for a replacement for my 750g that I've had to RMA and I was looking at the AX series from Corsair and from what I understand the AX series is the cream of the crop especially the ones with corsair link is it worth the extra money and also are there any better corsair power supplies? Also is the AX series top of the line for corsair PSUs?
I was looking at this one specifically
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139043 i version
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139042 non i version
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
For the extra $20, I would do it. I believe you have the ability to monitor power usage.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
There is also the RM series which is also very good. C-Link is stupid IMO. The RM series is cheaper but gives close to the same performance.
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
No not really.
for PSU's, no really
So the only difference is that they are charging 20 dollars more just for the software or is there some different hardware in there?
Hope I could help!
It is digital you can control and look at other details for the PSU. Also you can change the fan curve.
Quote me to get a reply!
I don't personally have it but I haven't heard anything bad about it. Is it worth it? maybe not but I don't think it could hurt. Maybe looks up some reviews?
For 20$ i would  gladly buy the digital version. Also I have read people having coil whine issues with the non i version. I don't know if they have fixed it yet.
The only way to deal with an unfree world is to become so absolutely free that your very existence is an act of rebellion.
I have corsair link.  I got the 860i for same price as the ax860 non I so I said why not. Its preey cool you get to see like every single detail possible.
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
It's subjective. If you think monitoring your PSU for $20 is worth it and you have the money, then go for it. The manufacturers are different (non digital one is made by Seasonic and I don't remember who manufactures the digital one), but we are talking about Corsair, so you can't really go wrong. The AX series (both AX and AXi) has the highest end components and the best effiency out of all the other Corsair series of PSUs.
#OhCrap #KilledMyWife
The two psu are completely different designs. Both excellent, but different. The AX860 is built by Seasonic and based on their KM3 platform, http://www.hardwaresecrets.com/article/Corsair-AX760-Power-Supply-Review/1687/13. The AX860i is built by Flextronics, http://www.hardwaresecrets.com/article/Corsair-AX760i-Power-Supply-Review/1668/12
