Network Flow Meter?
Solved by mynameisjuan,
45 minutes ago, ELECTRISK said:Why are they a bad choice? They serve me just fine.
100meg ports and 2.4g only. Pretty poo.
If you really really need a physical device get this or the 2011.
It has a screen with real time bandwidth per port/bridge.
Or you use netflow/snmp. The reason a device does not exist is it needs a CPU to process the statistics. Essential just a two port switch.
