I have a 2600K and a Maximum V Formula in a GD08 which I want to use for running netflix, 4K content (movies....etc, zero gaming), im guessing the HD 3000 graphics will be too weak but I would like it confirmed?
If I did have to buy a graphics card, which is the best solution for best picture quality/use case stated above?
Not graphics related:
Would I need to run a cable from the motherboard I/O for the SupremeFX IV – AMPed audio to work, or will it work normally through a HDMI cable?
Monitor: Alienware AW2518HF CPU: 9900K @ 5.1GHz Heatsink: 2x360MM Custom Loop GPU: MSI GeForce RTX 2080 Ti GAMING X TRIO RAM: Patriot Viper Steel DDR4 2x8GB 4400Mhz Mobo: Asus Maximus XI Gene Case: Fractal Design Meshify S2 PSU: Corsair RM1000x Storage: Seagate Firecuda 510 2TB M.2, Adata XPG SX8200 PRO 256GB M.2
https://linustechtips.com/topic/1037038-do-i-need-a-graphics-card/
You want to run netflix in 4K? You need at least an 1050 with 4 gb. Other 4K content a 1030 will also works. Or for AMD equivilant an RX 550/560. Dunno if AMD Polaris (RX 550/560) will work with 4K netflix tho
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
hmm so I've got two completely difference answers....
Naisu, at least were both wiser, thanks for posting
Well if you want tot use a 4K monitor then you will need a graphics card. The HD 3000 can't do 4K. At least not at 60hz anyway. But I guess if you are not gaming, maybe you don't need 60hz?
According to the specs for your motherboard it doesn't do 4K. I expect it will though just at 30hz.
Basicly it comes down to: Do you have a 4K monitor?
If you DON'T then you don't need a GPU.
If you do, then you need one to get the monitor to work at 60hz or maybe even at all.
If you don't have a 4K monitor then you don't need 4K netflix. Except for the higher bitrate which is pretty unimportant.
Gaming Rig:CPU: Xeon E3-1230 v2¦RAM: 16GB DDR3 Balistix 1600Mhz¦MB: MSI Z77A-G43¦HDD: 480GB SSD, 3.5TB HDDs¦GPU: AMD Radeon VII¦PSU: FSP 700W¦Case: Carbide 300R
Ive got a 60" 4K TV, it's for the living room
Well if you want netlfix in 4K I would check out this article
https://nvidia.custhelp.com/app/answers/detail/a_id/4583/~/4k-uhd-netflix-content-on-nvidia-gpus
and also I believe you needed at least an HDMI 2.0 cable
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
Then yes you need a GPU capable of displaying @ 4k.  There are a lot of GPU's capable of displaying at 4k, but doing any content in 4k is another thing.  Im redoing my HTPC and putting in an old R7 260x, it can output HDMI @ 4k 60hz...not sure if it will be capable of Netflix yet though.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
the video card needs to have hdmi 2.0 to do 4k 60htz...other wise it needs an adapter (hdmi 1.x to 2.0 even dp to hdmi 2.0 works)
amd 560 or better nvidea 1050 or better...the earlier cards all require an adapter... amd 400 and 300 series and nvidea 900 series (i believe some of the nvidea 900  and amd 400 do have hdmi 2.0 depending on who made the card not sure thou)
Would you say that I should really go for a 1060?
1660ti. 1060 is outdated now. 1030 does HDMI 2.0 but apparently won't do UHD Neflix according to Nvidia. At least a 1050 is needed so you may as well get something that can do a decent job at gaming. Or just go AMD where there is no artificial gimping.
Really though it would be better to just buy a new PC. The cost of a 1050 even is getting toward half of what a new PC might be. Apparently HEVC decoding is the reason newer hardware is needed, Kaby Lake and newer CPUs have it built in.
Alternative you can upgrade your platform to 7th gen Intel or up and get the same result ? . Might be an most costly investment but it will repay itself in the long run
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
I don't really follow any of that logic as you'd still need to buy a new PC ontop of 1050?
Or is the built in graphics of the 7100/7300 the same power as a 1050?
they are over stating.....for playback 4k 60 youll need a newer intel cpu with the newer igpu it has, is what they are talking about, if you didnt get a video card.....or just get a 1050ti or amd 560....your cpu is fine as long as you have a video card to do the video playback
Not the same power but it can do 4K and the built in graphics of older Intel CPUs can't. If you get a 7th gen or newer CPU you don't need any GPU, the built in one is good enough.
  • 1 month later...
For those who might find this thread useful I ended up buying an RX570 today, thanks to all for your advice
