Do I need extra cooler for Ryzen 5 system with Vega 11
4 hours ago, LightParticle said:Well, thank you very much paddy-stone, and other members too, but on another pc forum I got the answer on my question which is says that I need a kind of "standart: 1 income, 1 outcome cooler. (TOMShardware: threads/how-much-coolers-do-i-need-with-intergrated-graphics-card-on-ryzen.3453108/).
Case I may use can be with grid on front panel, but I don't sure yet, maybe it will be just a front panel (it depends on what models I will have on the market). By anyway exhaust cooler on case what I looking for is for sure wil have cooler in the back , not on the top, because top cooler cases are mostly for gaming or great performance build.
P.S. I need to make clear my previous post. Experienced pc builder is told me that 1 exhaust will be enough, not "not enough", but anyway it don't make paddy-stone post less useful.
Ahh I see, yes it helps if you put the correct term... if you say
5 hours ago, paddy-stone said:1 exhaust will not be enough for my specs
Then it means you need more than one. Not that "one will be enough", it makes a BIG difference the order of the words. But anyway, glad we cleared that up.
When they say that "standard, will be one intake and one exhaust" that means that is what they would recommend at the minimum, because then you have fresh air coming into the case, and an exhaust helping to push the hot air out and to keep the air in the case flowing over the parts. And yes, that actually COULD be sufficient for your needs.
I however would recommend to have more intake fans if the case allows for it, and because it's seeming to be a trend lately to have cases with not so good airflow. Anyway, good luck with it
