Need help mounting motherboard to custom pc case
Solved by W-L,
3 minutes ago, castkevi845 said:Unless the standoff screws won't conduct electricity to the motherboard but I'm not sure about that.
The standoffs will conduct and is designed to do so as an extra ground plane. As long as the stand offs are tall enough to ensure the motherboard solder joint don't make contact with a metal tray and in this case since there is an acrylic barrier there is no worry.
Featured Topics
LHJKO ·
Posted in CPUs, Motherboards, and Memory2 -
DrewRomine ·
Posted in Programs, Apps and Websites2 -
VinSen ·
Posted in Troubleshooting3 -
MrZoraman ·
Posted in CPUs, Motherboards, and Memory18
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
