Using An entire Drive for backup?
Solved by vanished,
1 minute ago, LuckyAsFox said:Ummm. A bit confused xD. So if I had a full 1T drive and I imaged it onto another drive how big would it be approximately,? and how would I use my image I stored on my backup drive to restore my corrupt main drive?
if the drive was 1 TB and full of data, the image would be about 1 TB. You would use the same software that created it in order to restore the data to a new drive, if and when necessary. Depending on the format, it may be possible to use other software as well, if it's a generic and common format rather than something proprietary.
