So I just bought a Raspberry Pi 3 Model B but didn't realized it didn't come with a power supply. The Pi says 5V 2.5A but the only thing I have that comes close to that is 5V 2.4A, would this be an acceptable amount of power for the Pi?
CPU: Intel I5-7500
CPU Cooler: Cooler Master ML240
Motherboard: ASRock B250M PRO 4
Memory: 16GB Patriot Viper Elite
Gpu: Asus Dual 1060 3GB
Storage: Corsair 120GB M.2 NVME
500GB Samsung 860 EVO
1TB WD Blue
Power Supply: EVGA 500W 80+Bronze
Case: Phanteks P350X
Monitors: HP Omen 25in 144hz
and some 25in Acer
Keyboard: Corsair K70 LUX RGB
Mouse: Corsair M65 Pro
Headphones= VModa Crossfade Wireless(but used wired)
Speakers: Some janky speakers I jerry-rigged
https://linustechtips.com/topic/1030322-raspberry-pi-3-b-power-help/
You'll be fine. Unless you overclock or something crazy the power supply should be more than enough.
USB connection on that pcb only supports power in up to 1800mA, So yeah 2,5A(2500mA) is just to be safe that voltage 5,1v dont drop too much under 5v line...
But be awear if your 5v 2,4A PSU didnt come with that Micro USB cable then you may lose your power on there specialy on long and thin ones!
little example video
I run most of my Pis on 1A power supplies.  My Pi 3 has a 2A supply.
The thing is, it really depends on what you have connected to it.  The Pi 3 series are more power hungry because of their onboard wireless, but it's still reasonable.  Start adding things like HATs and USB devices, and you could soon brown out the system.
