Ive built my gaming PC now i need a worth monitor
spellmanuk
so I've built my new gaming machine,
Ryzen 7 2700
16GB RAM
GTX 2070
I have one issue my monitor is poop, its a Samsung S24H650 24" 60Hz 1080p panel obviously my computer is way overkill for this monitor so I'm looking for a good 1440p ultrawide with G-Sync if possible but not nessicery.
I lurk a lot
Nice rig.
What is your budget, intended use is gaming I assume?
Current System Specs:
MOBO: Gigabyte Aorus Ultra Gaming     CPU: Intel i5 9600k      GPU: EVGA GTX 1070 ti FTW Ultra Silent    PSU: EVGA 750 G2 80+ gold
Ram:  16GB Corsair Vengeance RGB Pro DDR4-3200    Storage: 500 GB Samsung 970 EVO/ 4TB WD Blue Case: Corsair 275R-White
MX34VQ for cheaper with freesync (but works with gsync), if you have money to spend AW3418DW
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
28 minutes ago, Mira Yurizaki said:
How much money do you have to spend on it?
28 minutes ago, RogueCow said:
Nice rig.
I'm thinking less than like £700 if possible i know that 1440p ultrawide aint cheap
I lurk a lot
Doesn't the Acer Predator X34 fall into that price range?
I believe that is pretty much the best you can get for ultrawide gaming.
That said, it may have a freesync cousin(now works with Nvidia 10/20 series cards) that may be a little less expensive
honestly freesync/gsync is just a bonus for me it doesn't really bother me
what do you guys think about this one?
its 100Hz and its only £580
https://www.amazon.co.uk/dp/B073RJY7HH/ref=psdc_428652031_t1_B07FBL6WSC
I lurk a lot
