So if I enable flight mode and view it, it's considered read, but whatsapp wont show I was online?
I don't think so, you couldn't possibly be sending any data, it might resend when you reconnect though.
So it might be better to go with one of the last seen blocking apps if you are on Android.
https://linustechtips.com/topic/102969-whatsapp-help/#findComment-1377228
Arent you a little paranoid? O.o
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/102969-whatsapp-help/#findComment-1377246
You should be okay, I think this is exactly what the hide last seen apps do anyway.
In fact I think aeroplane mode might even be slightly better. I have noticed the odd time if you just disable mobile data and wifi, it can sometimes still connect very briefly, with aeroplane mode it locks down the phone completely.
https://linustechtips.com/topic/102969-whatsapp-help/#findComment-1377259
Hook up with her? :D
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/102969-whatsapp-help/#findComment-1377404
