Its my first time building a gaming pc and I have chosen these parts but Im not 100% sure if to change them or not. My budget for a gaming pc build is around £1000, I am alright with spending a little over so around £1100. I would mainly use it for gaming and not productivity as I have a laptop for that. I need either suggestions or anything which changing would benefit me either in price lowering or performance. I also plan to get a 144hz monitor a little after I build my computer. So would these specs be enough to get close to 144hz or more than in some games. The games I would play would be csgo, league, rainbow six, gta, outlast, overwatch, battlefield v, blackops etc.
Parts list -
evga gtx 1070 ti sc black - £460
Intel i5 8600k - £250 (Im very indecisive, aint sure whether to change to amd or keep this intel cpu)
corsair vengeance 16gb 3000 led - £116
msi z370 a pro mobo - £112
Cooler master hyper 212 cpu cooler - £24
evga 600w psu - £44
nzxt h500 case - £70
seagate 1tb hdd - £40
kingston 120gb ssd - £20
Total = £1,136
https://linustechtips.com/topic/1029005-moving-to-pc-gaming-need-help/
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
- GTX 2060, same price, higher performance and newer.
- Ryzen 2700x, 8 threads & 16 threads
- No cooler needed for ryzen
- If you have money to buy a 1070ti, why use cheap kingston ssd? Get a samsung or crucial.
Just now, Tevildo said:
So not go for the i5 but go for a amd cpu. Also change to a 2060. Know any motherboards that goes with the cpu and I can overclock a little?
Why the 2060 when you can go with the Vega 64 (or 2070) and still be within the £1000 budget? (See my edited post above)
Unraid Server
1 minute ago, Tevildo said:
Im mainly looking for performance though, is the vega 64 close to the 2070 or 1070?
It depends on the game. But generally it's 2070 > Vega 64 >>> 1070.
Unraid Server
In my personal test the V64 performs basically the same give or take some as a 1080/2070, just depends on the game.
Current Build
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
I would mainly play games like overwatch,csgo r6, gta, bf5 etc and I would get a 144hz monitor too.
Vega 64 is good too, but more expensive and power hungry, it should be in the 1080 performance.
You can also buy a Vega 56 and mod it to 64 for free (if you're lucky to have the samsung chip in it).
I have a 1440p 144hz most games i can get 1440p90 even on highest settings, 1080p 144hz should be no problem.
Current Build
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
What's the RNG on getting a samsung chip?
Current Build
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
3 minutes ago, Tevildo said:
Would I be able to overclock the amd ryzen 5 2600 so it would match the amd ryzen 2600x?
Easily, 2600x is just an overclocked 2600. I've seen it overclocked to 4.2ghz.
This is if you're lucky enough to have a good chip.
