No, definitely not.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12257880
Maybe past 150-200FPS at 1080p it may see the CPU put up more of a fight to do more..
But that GPU is for 1440p High refresh (120-165hz) or better yet 4K 60-100fps,.... being more demanding to make use of it...without the CPU asking to waste cycles on 200+ FPS like 1080p would.
If your playing on 1080p panels, use RTX if available, or Nvidia DSR 4K to inject more details on screen making more use of the GPU.
You CPU is great "up to a point" but even saying that,... the 8700K is no slouch for Gaming,.. expect 150FPS+ at 1080p always or better in most games but the ever so broken "not meant for above 60" type games.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12257904
Current gen high end components, not to mention expensive. Really should be a no brainier.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12257938
You can not not have a bottleneck. No matter what components you have, something will always (!) be maxed out earlier. When do people finally start to understand what the heck they're talking about. A 2080Ti at 1080p will always be bottlenecked, even by a 9900k or *insert next gen behemoth here*, at 1440p there will still be some bottleneck but a smaller one, at 4k the CPU will be bottlenecked because the GPU is limiting fps. Beyond those general things the specific load is very important. This is like asking "Will those tires bottleneck the performance of my car?" Well, if you have a 400bhp engine then 195 wide tires rated for a max speed of 180kph will probably limit the performance, yes. If you're in the US and are using the car for driving to the shops, then it won't matter.
It's really not rocket science. Just apply some common sense when choosing your hardware. If you want more details just look for comparisons and benchmarks by reputable tech bloggers and youtubers.
There should be a drinking game: whenever "bottleneck" gets mentioned you take a shot.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258000
CPUs don't get bottlenecked by the GPU because the CPU is not reliant on the GPU to do any work.
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258034
What is it called when you have unused CPU potential then? Obviously when a GPU is at less than 100% it's a bottleneck because the CPU can't keep up, but if the CPU is at less than 100% and the GPU can't keep up then how is that classified?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258045
If you want to label something as a bottleneck, then it's software unable to give the CPU enough work in a slice of time.
But if you're paranoid that your hardware is not running at 100% for most use cases because you think having both run as close to 100% as possible is ideal, then I suggest running lower-end hardware.
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258081
I mean, I've heard that 100% GPU usage is best, as well as low CPU usage (or just under a hundred), but while that's true as a super general rule, it leaves out important details like what the CPU and GPU are. For example, a GT 730 and an i9 9900k, there's an issue there in gaming. The GPU will be at 100%, not bottlenecking the CPU but bottlenecking the experience, trashing gaming performance. The user is the one waiting one the GPU to do its job, as opposed to the components.
Also running closer to 100% usage in a sense is a good idea honestly, an i7 8700k would be nice to have sometimes but if your library won't be needing all that CPU power then an 8400 would be great, save some money and get the same performance.
Ultimately I don't think it's inappropriate to classify bad GPU performance as a bottleneck, because it can't handle the tasks assigned to it fast enough to make the experience good.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258095
That's basically the exact opposite of what I was saying ...
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258118
That's the most ideal situation to have here when it comes to resolving performance issues because the GPU is last in line to push frames out (I guess technically the monitor is, but let's leave that out for the sake of argument)
Quote
This doesn't leave you with extra headroom in the future when a game that does use more CPU power during action packed scenes, causing it to slow down the overall experience.
Quote
I'm not saying it's inappropriate to classify a bad GPU as a bottleneck. It is a bottleneck. What I'm saying is it's inappropriate to say the CPU is bottlenecked by the GPU. The GPU can't do anything until the CPU has done its work. But if the CPU is done with its work before the GPU is done, then the CPU will either spin or go off and do something else before it needs to run the game logic again. If GPU performance really did determine CPU performance, then something like run times of 3D Mark will vary based on GPU performance. Except 3DMark is a fixed-time benchmark.
That statement was not meant to be taken seriously, but to point out the absurdity of the argument.
Anyway, bottlnecking is not a problem. It's a symptom of a problem. The root problem is "does the system provide the performance that the user wants?" If the answer is "yes", then we can go about our merry way. All finding a balance is doing is min-maxing the value proposition. I mean, if that's what the user wants too, then by all means, go for it. I don't expect nuggets to figure this out, especially with popular TechTubers not even explaining the thing very well, but the question that should really be asked here is something like "I have an i9-9900K with an RTX 2070, will I be able to get ## FPS at #### resolution in most games?"
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258153
I'm not saying it's inappropriate to classify a bad GPU as a bottleneck. It is. What I'm saying is it's inappropriate to say the CPU is bottlenecked by the GPU. The GPU can't do anything until the CPU has done its work. But if the CPU is done with its work before the GPU is done, then the CPU will either spin or go off and do something else before it needs to run the game logic again. If GPU performance really did determine CPU performance, then something like run times of 3D Mark will vary based on GPU performance. Except 3DMark is a fixed-time benchmark.
Sorry for asking a stupid question like that. I see a lot threads everyday about
people asking the same question to a level where it got me worried.
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258158
There's no such thing as a stupid question if you aren't intimately familiar with the topic. :)
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258166
My statement wasn't against you, it was about the exact thing you already noticed: people asking the same question over and over and over again.
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258179
At that res you would be good. Anything lower, cpu could struggle on some games.
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258657
Yeah i understand now. Like getting a powerful gpu to play on 24 inch monitor 1080p of course there's gonna be some bottleneck. Because that gpu is made for higher and extreme resolutions? Am i getting the right picture in here?
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258917
Wouldn't say cards are made for certain resolutions, just scenarios. Like what card you think can push enough frames to use 240hz 1080p monitor properly?
Like my 8700k hitting low to mid 90% usage playing games on 1080p, if I had a stronger card than a gtx 1080 I could get some issues stutter wise.
But in your scenario, the parts should compliment themselves nicely.
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258935
Like as long as im not hitting the maximum frames i wont get a bottleneck?
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12258963
8 hours ago, charbel1011 said:
at 100hz there's no cpu bottleneck in 99% of games on the 8700k
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12259057
As in if the cpu can keep up with the frames the card can produce. Wouldn't say theres a max.
https://linustechtips.com/topic/1028865-will-it-bottlneck/#findComment-12259061
