So for xmas i built my second computer. I recently learned that ram doesnt start speed isnt what you buy it as and you have to overclock it to have it at a higher speed. I have 3200mhz trident z rgb ram paired with a ryzen 2700x on a asus crosshair xii hero (wifi) motherboard. Now when i went into the bios and overclocked the ram i set to 3200mhz and pc wouldn't start. so i lowered it to 3000mhz and booted with no issues. So i was wondering why i cant get it to 3200mhz. any information or advice is greatly appreciated.
https://linustechtips.com/topic/1028180-need-some-help-with-ram-overclocking/
what does CPU-Z read in the memory tab?
Desktop benching:
Make sure your BIOS is up to date, AMD has released SEVERAL AGESA updates for RAM compatibility and stability. Afterwards you may need to adjust your RAM timings and voltage to get it stable. Here's a nice Techquickie video on understanding RAM timings:
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
8 minutes ago, rcmaehl said:
Make sure your BIOS is up to date. Afterwards you may need to adjust your RAM timings and voltage to get it stable. Here's a nice Techquickie video on understanding RAM timings:
bios is up to date thats the first thing i did after putting it together. and i will look into this video see what i can do. i was worried about playing around with those setting casue i dont have the money to replace the ram if i mess up the ram.
Wrong timings won't mess up the RAM, but setting voltage higher than like 1.5V definitely will.
What's the voltage set to for DRAM? When I used that motherboard I went up to 3600 on my Flare X Samsung b die. I think at 3200 I left it on auto but I adjusted it manually to go higher.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
im not sure i wll have to check the bios and see what its at
I think you can tell with HWInfo, you should download that anyway. Run it with 'sensors only' and scroll down to Memory. Im not on the computer so bare with me.
Are you using DOCP to set your RAM speed, voltage, and timings?
And did you install the RAM into the correct slots?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
So when you change Memory Frequency to 3200 it fails to boot?
Yes it will get to the splash screen for the mother board and then it will error out and says the motherboard returned to base settings or somthing along those lines
Go into External Digi+ and scroll to the bottom.  There you can set the DRAM Boot Voltage to something higher.  1.4V will get the job done and not hurt anything.  If that doesn't work then try a little more DRAM voltage.  Something like 1.36V or a touch more if needed.
So I went to go change the setting you suggested but it doesnt allow me to change it.
DRAM VBoot Voltage is what we need.  You can't type a value into the field?
  • 2 weeks later...
2 hours ago, mike551345 said:
no i can not. sorry for the late response hope i can still get some help i have to deal with family issues and havent been paying attention to this.
It's present so I can't imagine why you wouldn't be able to type into the field.  If you can't though see if once it's selected you can use the + key to increase the value to something like 1.45V.  It isn't the operating voltage so I wouldn't worry about setting it too high.
