hi guys i recently installed a corsair H100i cpu cooler but i have accidently installed the upside down on the top of the case so its pulling air in not pushing it out, everywhere i read it says it should be installed with the air pushing out the case if the radiator is installed on the top, my cpu is running fine and stays around 65 degrees under load, apart from having the rgb lights being on the wrong side is there any problem having the fans this way or should i turn the around?
Thanks
https://linustechtips.com/topic/1027747-rad-fan-positions/
You should probably turn those fans around, you want to push air through radiators and not pull it. When that GPU and CPU get pushed the CPU is going to heat up and the case will become very warm on the inside.
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248159
You want your PC set up like a hair dryer.  Not a home.
Cool air in, hot air out. You have a lot of cool air coming in, getting hot, and minimal way to get out.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248172
Push or pull doesn't matter in the slightest to the radiator, you'll get basically the same results either way.
You might end up with slightly more dust in the case, but you probably aren't going to experience any other issues with it.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248173
 I did think that but but my cpu and gpu temps are fine both around 65 degrees while gaming (BF5), would i get cooler cpu temps with the fans the other way around??
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248174
Your CPU temps probably won't improve, your GPU might run slightly cooler though.
¯\_(ツ)_/¯
Desktop:
Laptop:
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248188
Thanks
You should be perfectly fine. You'll be going for more of a very positive air pressure system, but that's not a bad thing. You can flip the fans around, if you'd like to see dem sexy RGB goodness a bit better, especially if you have other intake fans bringing in that nice cool air. Otherwise, if you have a fan or two pulling hot air out of the system, you're good.
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248217
I have 3 x 120mm fans on the front of the case and a 120mm exhaust fan on the back
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248249
Yeah, you should be perfectly fine. Lots of positive pressure, but that simply means you're making those air filters do their job. Make sure you clean them out every 1-3 months, depending on how dusty the environment is(keep an eye on them to see how often they are getting dirty, giving the interior a spray with a can of air a few times a year is an awesome way to take care of it).
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248271
BF5 isn't exactly the most intensive game depending on settings, GPU etc. etc. You may not have an OC running but long sessions of very intensive games like AC odyssey will definitely get some heat buildup in there.
The Louvre
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248285
In a case with an RTX card? I would not want to be pulling air in that will get sucked up by the GPU, get replaced by heat and then travel up towards the rad. Heat rises ?‍♂️
The Louvre
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248290
Heat rises, but fans don't care what way the air would normally go. The GPU would probably be running hotter though.
¯\_(ツ)_/¯
Desktop:
Laptop:
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248309
i been using Nvidia experience settings with ray tracing turned on a 1440p 144hz monitor, my cpu usage it around 70%, i thought that was pretty intensefor the cpu
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248311
70% stock freq? Most modern FPS titles don't pin a system like open world games will because there's not as much to interact with, explore, render etc.
The Louvre
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248416
yeah i7700k stock, (will be overclocking soon) i have only played BF5 since having this gpu so will look at a few open world games and see what happens
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248455
Ahh that's why was gonna say. My 9600k only hits that kind of usage in really demanding games. COD/BF are easy on it w/ max settings and an OC.
The Louvre
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248473
Any proof for that? Performancewise there's no significant difference. Sure, depends on fin density, specific fans, rpms etc but push or pull doesn't make a significant difference that exceeds the margin of error. Pull offers the advantage of not having dust between fans and radiator but on the easily accessible outside. Potential dust build up will have a far greater impact on a radiators performance. A case is too small though to have the air on the inside have big temperature differences. You will need some exhausts though if the case isn't designed for positive pressure.
One exhaust and 5 intakes? I'd think about switching around. How about front as exhaust and back and top as intake? You'd need toadd a filter for the rear fan assuming there isn't already a filter isntalled.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1027747-rad-fan-positions/#findComment-12248818
