Silent case fans?
Go to solution Solved by WoodenMarker,
2 minutes ago, Frosty! said:
The stock cooler that came with the case is not controllable.
But it can. Whether a fan can be controlled depends on the header you plug the fan into and not the fan itself.
The motherboard only has 2 fan headers which you should be using if you want any fan control. What headers did you plug each fan into?
If you're not sure what case fans you have, post some photos of them.
1 minute ago, Frosty! said:
Hi there,
just bought the AT2020 microphone but what I already expected, happened.
My case fans are far too loud
What case do you have?
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232083
Artic or fractal make cheaper priced fans.
But,
I highly recommend beQuiet.
https://www.bequiet.com/en/casefans
I also recommend Noctua
https://noctua.at/en/products/fan
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232123
What are your specs? Have you tried lowering fan speeds?
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232161
24 minutes ago, Frosty! said:
Sorry for the late response.
on my cheap ass fans it’s not possible to change the speed. :D
That wasn't late at all. This is a forum and not a live chat so it's pretty normal for replies to take a day or so.
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232374
Am my bad didn’t read that question.
I currently have:
Thermal take h15
i5 6500
gigabyte H110M-S2H
16gb ddr4 2133mhz
1060 6gb
cx550m
Note:
I am looking in to upgrading to an Ryzen 7 2700X with a 450m motherboard and 3000mhz ram. So I’ll probably do this in a few months!
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232411
gigabyte H110M-S2H
Are you referring to the stock case fan? It should have a 3pin fan connector and can be controlled through the motherboard's sys_fan header.
Are you using any aftermarket fans?
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232426
The stock cooler that came with the case is not controllable. I have 2 fans in front but no clue what brand whatsoever, it’s from AliExpress so I can’t expect much.
On my CPU I use the stock cooler
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232442
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232459
Alright dumb me!
I got it working!
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232469
1 hour ago, Frosty! said:
Any specific Noctua and be quiet fans?
I have the silent wings 3. They are very quiet.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1025820-silent-case-fans/#findComment-12232492
