Hello, I want to build a gaming pc with very minor video-editing. But to be frank, I'm not sure what to build. I have a 1080p 144hz monitor already because my friend recommended me it. I would like liquid cooling, and i7-8700k, if possible. My budget is 1500 USD - 2000 USD. I would like to the budget to be closer to 1500, but if it is closer to 2000, I will still be okay with it. I play League, Fortnite, Dota, Pubg, Monster Hunter, and would like to play some graphically intensive games as well with this build. Thanks for taking your time and helping me. Cheers.
https://linustechtips.com/topic/1025565-need-help-on-building-a-pc/
I would honestly get the 2600 and upgrade when Zen 2 is released, there will be way better options then. If you need more cores you can get a 1700X for around $200 or less.
EDIT: My bad, I like literally forgot you mentioned the 8700K.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
15 minutes ago, DweJiBah said:
I also would like the build to be white with rgb lighting if possible!
Which country? Need os/peripherals?
On 1/25/2019 at 12:25 AM, MegaLukey said:
There is alot of information missing here, but id say go for a 2070 to match the 8700k . And go ahead and pick out whatever white parts you want that you can fit into your budget.
What information am I missing?
3 hours ago, DweJiBah said:
US and I would only need OS.
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  ($359.99 @ Amazon)
CPU Cooler: Cooler Master - MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($154.89 @ OutletPC)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  ($183.26 @ OutletPC)
Memory: V-Color - SKYWALKER PRISM RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($99.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  ($57.99 @ Adorama)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.50 @ Amazon)
Video Card: MSI - GeForce RTX 2070 8 GB Video Card  ($479.99 @ Newegg)
Case: Corsair - Carbide Series 275R (White w/Tempered Glass) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Corsair - TXM Gold 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($98.99 @ SuperBiiz)
Total: $1613.58
Generated by PCPartPicker 2019-01-26 21:45 EST-0500
