Something little but any help would be appreciated
Basically the 1TB G HDD (My Green Enterprise drive) dosent have a windows drive image next to it like (E:) and (C:) do!
My ocd is getting to me!
Any fix?
work it ᕙ༼ຈل͜ຈ༽ᕗ harder, make it (ง •̀_•́)ง better, do it ᕦ༼ຈل͜ຈ༽ᕤ faster, raise ur ヽ༼ຈل͜ຈ༽ノ donger
ᕙ༼ຈل͜ຈ༽ᕗ HARDER, BETTER, FASTER, DONGER! ᕙ༼ຈل͜ຈ༽ᕗ
https://linustechtips.com/topic/102549-drive-picture-missing/
Try unplugging it and plugging it back in &while the computers off)
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/102549-drive-picture-missing/#findComment-1371787
right click on it, properties, go to tab adapt (or sth like that), then restore.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/102549-drive-picture-missing/#findComment-1371805
delete desktop.ini file if you have in the root of that drive (you need to able to see protected windows files enable that through folder and search settings)
if that didnt help check this
http://www.sevenforums.com/tutorials/49819-icon-cache-rebuild.html
https://linustechtips.com/topic/102549-drive-picture-missing/#findComment-1371836
autorun.inf (if one exists) can also point to an icon to use as the drive icon, so if it points to an icon that doesnt exist you would probably get that icon showing.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/102549-drive-picture-missing/#findComment-1371925
ok i will try this when i get back home
Thanks for the reply's!
https://linustechtips.com/topic/102549-drive-picture-missing/#findComment-1372318
