What would be more favorable on a PC build?
1: A computer not that fast but very stable and with an specific porpose in mind.
2:A computer really fast and topped off with general porpoise but ultimately unstable and unpredictable.
I'm asking this because my friend has a PC more powerful than mine but very oftenly he runs into crashes into very simple aplications such as Aseprite and Construct and also blue screens on very well optimized games such as League of Legends.
I usually run League of Legends at from 60 to 70fps on lower settings and his PC runs it at around 180fps on high to max settings.
I don't really remember his computer's specs but here's what I know.
Friend's PC:
CPU: AMD Phenom II X6 1090T Six cores 3.2Ghz-3.6Ghz 9Mb cache
GPU: GT 430 1GB DDR3
RAM:8GB DDR3 (2x4GB)
My PC:
CPU: intel core i7-3517U 1.9GHz - 2.4Ghz duale core hyper threaded
GPU: intel hd4000 350Mhz 32MB(dedicated) 128MB(shared)
RAM: 4GB DDR3 SODIMM
Hi, I am from Brazil and I pretend on building a Ryzen 2200G build. (to convert to Brazil's currency look up <your currcency> to BRL)
https://linustechtips.com/topic/1025267-stability-vs-speed/
Just now, GoldenLag said:
The faster and unstable
Downclock it to make it stable and use that sweet 8GB of Ram.
I'm yet to build a an actual PC, I'm planning on buying the Ryzen 2200g and 8GB of RAM (2x4GB), prices here in Brazil are salty as heck tho.
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12226749
Crashes mean you can lose data or, depending on the reason for the crashes, degrade components. Even without instability your friend's rig should be superior, so advise a lower performance target if you can.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12226752
Stability always. Besides that, your friends PC has issues, and I think ultimately you have better performing PC. Which you could make even better by adding another 4gigs of RAM and increasing VRAM for iGPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12228475
Stability.
Speed means nothing if it isn't stable.
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12228489
They are not mutually exclusive.  Your friends machine just has issues, no reason it can't be stable and faster than yours.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12228570
stable and fast, that's overclock done right
no need change my mind
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12228585
https://proxy.duckduckgo.com/iu/?u=https%3A%2F%2Ftse4.mm.bing.net%2Fth%3Fid%3DOIP.lnKd-DJbKui7cqh_LsMA-gHaHa%26pid%3D15.1&f=1 obviously.
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12228597
Friend's PC:
My PC:
Stability, if you cant play the game or run the application your PC is a POS.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1025267-stability-vs-speed/#findComment-12228630
