I have this weird problem when running games I have noticed it for about a month but in the last 2 or three weeks it has gotten a lot worse and is occurring more frequently.
My pc specs are
AMD Phenom II X6 1055T 2.8 Ghz
AMD Radeon HD 6870 1GB
Asus M5A97 AM3+ Motherboard
Corsair XMS 3 8GB ram
Acer V223HQV 21.5” 1920x1080 monitor
Xigmatek CPU Cooler
I have tried removing overclocks, changing graphics card fan speed the only way I know how to fix it is to open a YouTube video in full screen.
This occurs in Battlefield 4, Battlefield 3, Payday 2 and F1 2013
I have tried running other monitors and the problem still persists
https://linustechtips.com/topic/102482-weird-graphical-problem/
Maybe a problem with the port or cable coming from your GPU?
Edit: Or downgrade or upgrade drivers if possible.
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370599
Thats quite worrying, there is the chance that the gpus life is coming to end. If possible try different drivers, try another gpu. It could be that your gpus life is coming to an end.
Listen if you care.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370604
It appears to be a software problem, you say it only happens after playing these games?
try re-installing the games or verifying the game cache, this may help.
I have never seen such a problem before. It could indeed be a driver issue, try going back to an older version of your graphics driver.
Other than that you could maybe try reseating the cooler on the card, inserting it into a different pcie slot (if available).
Thats all I can think of for the moment.
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370607
Well. Your gpu is pretty outdated. Anyways. Did you use the same cable on the different monitors, did you use the same ports on the back of your pc? Its either something with the port, cable, drivers, windows or you have to start saving for a new gpu. However, it also looks like something I was struggling with on my old laptop, where my mobo got fried.
Ohh it only happens in those games? Drivers and game don't like each other. Actually it still could be alot of things...
I once explained to my girlfriend what true love is. I said, "If you were a shit, I'd put you back in" and to this day, she is still my little shit.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370611
I use DVI on my main monitor which is the one in the photos and when testing to see if it was the monitor i used VGA because it was a CRT. Running latest AMD drivers and i doubt any of the cables have become faulty and Windows 8.1 was installed mid November.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370617
I have extra PCI-E slots so i can try that and I can also downgrade drivers in terms of reseating the cooler i don't have a screwdriver small enough :(
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370631
I would suggest that reseating the cooler should be a last option fix. You could damage the GPU or any of the ram chips on it in the process and there are many other things that can go wrong. + you will need some thermal paste for when you put the cooler back on again. all in all it could be problematic but it could also solve some problems if you get to that stage.
As stated earlier a clean install of windows is a good idea too.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370635
Can you try the GPU on another computer, and see if the problem persists?
You could also reinstall the drivers...
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370706
I think I may of fixed it I rolled back the drivers and I was able to play a full round of Battlefield :) hopefully the problem doesn't persist if it does i will try some of the suggestions that you have provided thankyou for your help. It must been some sort of compatabiity issue with the latest driver.
Thanks
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1370758
Thanks
I'm glad we could help, just a quick note, what version of catalyst were you running? was it a beta version or just the most recent stable release?
You should report the bug either way but its even more important to do so if it was a "stable" release.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1373467
most recent stable release.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1376305
You should definitely send a bug report then because there will be many not as tech knowleged people with their 6870's that are installing the release as it is labeled as stable. They will then get a big fright.
https://linustechtips.com/topic/102482-weird-graphical-problem/#findComment-1376650
