Hello world im building my pc (like most of us) and i have one small issue I have no budget left for a win8 key (RRP $149,99)  I really want windows but dont have money for it....
Soooooooo Steam OS came to mind   why not install that    ????? well its new and I haven't heard anything cool about it.
So can you comment your experiences with Steam OS, Is it really that cool???
 hmm pirated windows........................................... im that desperate
Thanks all, Brandon :D
Edit- Would you recommend me use a trial version of win8 until I buy a legit copy, also if I use the trial can I active the key on it or do I have to reinstall.  Thanks All
https://linustechtips.com/topic/102462-steam-os-worth-it-help-please/
As far as I know, heaps of problems with SteamOS for users right now. I haven't seen a single screenshot or video regarding what it looks like either. I know nothing about the benefits of it over standard Linux or even Windows. Like @TheDoubleYGamer asked, I would be more wary about OS compatibility than anything. $80-110 for Windows doesn't sound too bad if it removes the chances of not being able to do anything on your computer..
I suggest waiting until SteamOS is more developed, or doing some additional research on it. I can't really help you because I don't think it's worth trying to find info on right now and won't search for it. There's also the problem of not seeing anyone say anything about it at all, so..
Steam OS is still quite in the beta stages, meaning you may have hardware driver issues. Have you had previous experience with Linux or familiar with command line?
I would suggest posting your systems specs via PC part picker to help find RRP $149,99 to use towards windows, the community members are very good at helping with this sort of thing.
Use the quote or multiquote, for faster responses \/ \/
Ok I understand hmm Its not as good as it sounds, Thanks for reply
Do you use any software that is only supported on Windows. So, is every program that you use on a regular bases supported on Linux/SteamOS?
No not rely but i'll like to get in programming so i would like if i could do that, I use skype, chrome,steam O,O, OpenGL and java needed programs :D
ok Thanks for reply
I think once steam os gets more support then it will be great but as of now its not very good, if you could have a dual boot to windows or steam then that would be nice.
Listen if you care.
Installing steam on a VM atm, the original had problems loading on my VMware so I downloaded this: http://directhex.github.io/steamos-installer/
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
SteamOS is specifically designed for the living room, hence why it boots directly to the big picture mode, my suggestion is for a desktop install a desktop Linux like Ubuntu of which you can install regular desktop Steam on there and even go into big picture mode if you want, but the main experience will be a desktop which is what you want.
Functionality between both is identical, but Ubuntu is specifically designed for the desktop.
Ubuntu isn't the only choice Mint is based of ubuntu with a different more windows like esque.
also more stable
There are a plethora of Linux alternatives, all of which are currently more reliable than SteamOS. At least until SteamOS is officially released.
ElementaryOS and Linux Mint are excellent.
A more bleeding edge option would be Archbang, an easier version of Arch. Could also look into Crunchbang, based on Debian.
Interested in Linux, SteamOS and Open-source applications? Go here
Gaming Rig - CPU: i5 3570k @ Stock | GPU: EVGA Geforce 560Ti 448 Core Classified Ultra | RAM: Mushkin Enhanced Blackline 8GB DDR3 1600 | SSD: Crucial M4 128GB | HDD: 3TB Seagate Barracuda, 1TB WD Caviar Black, 1TB Seagate Barracuda | Case: Antec Lanboy Air | KB: Corsair Vengeance K70 Cherry MX Blue | Mouse: Corsair Vengeance M95 | Headset: Steelseries Siberia V2
Mint :D
If you use the enterprise evaluation version then I think you will need to reinstall. I don't know if you can run a standard version for say 30 days before you activate like you can with Windows 7, if you can then as long as you use the same version you buy then you wouldn't have to reinstall.
I was going to suggest about trying something like Ubuntu while you save up for Windows then if you decide you don't like it buy Windows but if you do like it you have x money in your pocket.
Thanks I will try find a standard win8 trial and I will try to dual boot Ubuntu (Do you know If i can?)
Yeah you can definitely dual boot, install Windows first then install Ubuntu and select the 'keep Windows and install Ubuntu alongside' (or words to that effect), and it will do the rest.
Trying out this kind of stuff and which drivers work best are best to do before you activate Windows for a more permanent install because if you break anything you just reinstall and start anew, I always do that and make notes on what works best for a few days before I clean install and activate Windows, that way you start off with the cleanest install possible.
