USB 3.0 speed card readers
Solved by Kalamity.S,
7 minutes ago, UrbanFreestyle said:Thanks, Just checked it out and can see a review stating:
"The card reader in the Akasa is USB 2 only, while the USB 3 connection only feeds the 2x USB 3 ports at the front. This is not clearly indicated on the product description, which is a major omission. My Lexar USB 3 card reader reads a Lexar 1000x CF card at 120 MB/s, while the same card in the Akasa reader tops at 31 MB/s... "
oh,by the way,i just find another one.
this is sure is usb3.0‘s card reader,
but this guy is a 3.5'inch floopy drive place,u need an adapter lol
