Monitor recommendation
TheFishBucket
1 hour ago, TheFishBucket said:
Monitor for gaming!!!!
@TheFishBucket  Check out the Asus VG279Q it has everything you could want. 1080p IPS free sync 144hz 27 inches . Ive been using it and I love it!
CPU: AMD Ryzen 9 5900HX GPU: AMD RX 6800M RAM: 16GB  SSD: 500GB NVME
On 1/21/2019 at 4:19 PM, TheFishBucket said:
Hey, I’m looking for a 1920x1080p 120 or 144hz monitor with FreeSync.
I found this monitor but IDK if it’s a good deal as I never shopped for a monitor. Thanks!
https://www.bestbuy.com/site/msi-optix-mag240vc-23-6-led-curved-fhd-freesync-monitor-black/6303794.p?skuId=6303794
I would go with the model you chose. There is a good deal on it right now. It makes for a really good buy.
