The LL120's are probably better than the NZXT fans on the AIO. I don't think the X52 is enough, being only a 240mm AIO, but run some tests like the free version of AIDA 64 and post your temps in here after the stress test is done.
Something that you can do to help is slapping some noctua fans on the rad, that should help.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1023644-9900k-5ghz-cooling/#findComment-12212244
here you go, thank you!
https://linustechtips.com/topic/1023644-9900k-5ghz-cooling/#findComment-12212821
7 hours ago, jonathancccc said:
those max temps are too high for just aida64, i'd just lower it to 4.9 and settle there, not worth changing cooler for 100mhz.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1023644-9900k-5ghz-cooling/#findComment-12213044
should i keep it the same voltage or what? thanks!
And if i were to change my cooler, which cooler would you recommend from corsair?
im really digging the look of Hydro Series™ H100i RGB PLATINUM SE 240mm Liquid CPU Cooler, but im not sure about its cooler performance, thanks!
https://linustechtips.com/topic/1023644-9900k-5ghz-cooling/#findComment-12214419
You want to lower it as much as possible, lower it in tiny increments and run aida64 each time until it crashes, once it crashes, bump it back up one increment and run the test a few times to ensure stability.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1023644-9900k-5ghz-cooling/#findComment-12214508
you can probably lower the voltage by 2% of whatever it is you have on 5ghz, maybe a bit more, the cooler choice depends on your needs, i'd ONLY go for AIO if i want looks first, i've gone from air cooling, to aio, back to air cooling.
the 2 disadvantages of AIO is the lack of airflow on the mobo vrm and unreliable pumps. I'd stick with 4.9 and the current cooler unless you really like the AIO you are looking at :)
The only z390 motherboards i'd use without airflow to the vrm+AIO is probably from gigabyte, so it also depends on what motherboard you are already using.
https://linustechtips.com/topic/1023644-9900k-5ghz-cooling/#findComment-12214689
