Just a question, why would you get that high end board and pair otherwise mid range hardware with it?
As for upgrade path, you can try BIOS modding so you can fit a Coffee Lake CPU in there. The board's good enough to be worth the time. Not a good time to buy faster graphics cards anyway
Desktop benching:
Your motherboard is seriously overkill for the rest of the hardware you got.
Honestly you are on a bad spot... if you improve the GPU you'll need better CPU and faster memory to keep up with it and keeping the motherboard would mean limiting yourself to the i7 7700K which I'd pair only with a RTX 2070 as games become more CPU demanding lately.
Personal Desktop":
Luna, the temporary Desktop:
1 hour ago, Brass_01 said:
 can fit higher clocked mem
And you’re running 2133mhz?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Keep your RAM, change your CPU, there will be a bottleneck with a 2070 paired.  What is your budget for new mobo and cpu ,,,,, You can get a Gigabyte Aorus Elite or Pro use your RAM, and get a 6700k or 7700k and give her a turbo boost clock and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Maybe get something else I'd spend as much upgrading it to be fast but in the end less than the 8th gen i7 for the same price what do ya think 7700k still expensive as a 6 core I'd just go a lower tier motherboard buy the higher core count system.
