how to fix color scheme
Go to solution Solved by RayMurr,
Either Themes or Colors
I was playing with this piece of software called Wallpaper Engine. it's really neat. But I found out that steam was a huge idiot and installed it on the wrong drive. So I uninstalled it and reinstalled it on the correct drive. But now my windows desktop is in a weird green theme. The program borders, taskbar, and even the volume sliders are now this neon green. How do I reset this to default? Preferably not digging into the Windows registry, because I know that that is an option.
Hmm. RN im not on a windows machine so I'll try my hardest.
CPU: i7-8700k, stock | CPU Cooler: Custom Loop | GPU:
ASUS GeForce RTX 2080 O8G ROG STRIX OC Edition | PSU: EVGA SUPERNOVA 750W | RAM: 16GB VENGEANCE LPX DDR4 @2666MHz | Motherboard: MSI MPG Z390 Gaming Edge | Case: Thermaltake View X-71 | SSD: Kingston A400 240GB SATA | SSD2: 1TB Crucial SSD | HDD1: 2TB WD Blue 2.5" @ 7200rpm | Peripherals: Corsair STRAFE v1.0, G602 Mouse | Acer Predator X34
Go to Settings > Personalization Settings >  Themes
That should be the path
Glad I could help!
