you can do that while installing windows im pretty sure. just go into advanced and delete all the partitions, make a new one that spanns the entire disk and press OK and it should make all the small ones it needs too
Builds:
https://linustechtips.com/topic/1019250-erase-help/#findComment-12171604
hahaha 2 sec late
https://linustechtips.com/topic/1019250-erase-help/#findComment-12171610
Can also do so from Disk Management.
Right click on Computer>Manage>Disk Management, find the Disk, Format
PCPartPicker Part List: https://pcpartpicker.com/list/ZKsJvn
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor
CPU Cooler: Cooler Master Hyper 212 LED Turbo (Red) 66.3 CFM CPU Cooler
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 Solid State Drive
Video Card: Asus 3080 Turbo
Case: Fractal Design Meshify C ATX Mid Tower Case
Power Supply: SeaSonic PRIME Titanium 750 W 80+ Titanium Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Home OEM 64-bit
Monitor: Asus MG278Q 27.0" 2560x1440 144 Hz Monitor
https://linustechtips.com/topic/1019250-erase-help/#findComment-12171637
Ok, but I will be installing a new ssd and installing Windows to the SSD, will that also erase the HDD?
https://linustechtips.com/topic/1019250-erase-help/#findComment-12171677
you can still erase the HDD if you just delete all the partitions on it during install
Builds:
https://linustechtips.com/topic/1019250-erase-help/#findComment-12171680
Yes, as above, just insert the USB or disc, guessing USB though... go through install screens. When it asks where you want to install to, press advanced IIRC. Then delete the partitions on the HDD. Then select the SSD as the install location.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1019250-erase-help/#findComment-12171722
If you install a new SSD in your computer and install windows on it, just unplug the HDD completely, install the SSD and install Windows without the HDD connected at all.
When you're done installing Windows on the SSD, simply go back in PC and connect the HDD back. When Windows boots up, it will detect the recently plugged hard drive and make it show up like a regular hard drive.
Windows will still boot from the SSD and the HDD will just show up as a second hard drive. You can copy what you want to keep from HDD to your SSD, then go in Disk Management and select your hard drive and delete partitions or format them to erase everything on it.
https://linustechtips.com/topic/1019250-erase-help/#findComment-12171732
Good advice thanks! It helps a lot to have only connected the drive where the OS will be installed, trust me! ?
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/1019250-erase-help/#findComment-12173484
