Thats a little warm on idle, you might want to try to apply some new thermal paste and remount the cooler
Just now, haazey said:
But its brand new. just bought it from the company. they build it from scratch..
It happens, sometimes thermal paste may not spread as well as you want, or the cooler just isnt mounted that great.
If you don't want to do it yourself then send it back and get them to fix it
Okey, i guess i have to contact them tomorrow about it... seemed a bit high for just doing nothing.. :/ this sucks.
Welcome to the new world, get yourself a custom cooler suited for am4 slots. Even with a 160W tdp be quiet shadowrock 2 tf2 my so called 65 tdp ryzen 5 2600 cpu is about 10 degrees celcius hotter then my previous first gen intel 95W tdp cpu. after installation of 2 extra fans i'm finally getting temps in the 30's with this system!
1 minute ago, haazey said:
Phanteks P400 Glass case
Ah, that would explain it. The front of the case is pretty closed off so, that's most likely why it's a little hotter than usual.
Those temps are still safe but, if you want to go lower, you could get some more case fans if it only has the two. (One on front one in the back)
Make sure to quote or tag people, so they get notified.
 Yeah , its not that hard to mount fans right ? I could get two more
No, it's just 4 screws then you have to connect them to the Motherboard.
I'd suggest you put one more on the front and one on top of the case.
Nah, installing fans is super simple.  The pretty side is the intake side and the ugly side with the fan's specs sticker on the hub is the exhaust side.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
8 hours ago, haazey said:
Why one in the front ? Was Thinking Two on the top since its closer to CPU .. but idk. I have not built any PC just swapped gpu ram hdd etc . Worried i might installera fans wrong way ^^ have to Watch a youtube vid to be sure
I'd put an extra one in front because that should give your GPU some more direct airflow. And one on top for the CPU cooler.
Feel free to experiment with them once you have the fans.
Also, installing them isn't hard, the side that has the sticker on it is the back. That's where the fan exhausts the air.
Make sure to get 4-pin PWM fans because those can be controlled.
Sorry for the fuzzy picture its a screen shot of a screen shot.  But these are my temps an hour into Star Citizen with it still running and minimized.  Stock Wraith cooler I am using a Fractal Meshify case.  One fan front and back but the whole front and top are mesh.  I guess the openess to the outside air is making the huge difference between our temps.
^^^ Idle temps are a bit warm, but load temps are fine. Mine hits a max of 81C under full load with my watercooling loop (single slim 360mm rad shared with a Vega FE so it's not the most favorable cooling setup, but it's about the same temps as on my 280mm AIO, and this is after about an hour or running both CPU and GPU at 100% with torture tests). Hit about 85C max on the stock cooler in torture tests too, but real world usage is usually lower.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
So should i just see what happens if i remove The glass? But i have 3 cats, needs to be covered
Don't. There's no need to open your case up completely. Just add some fans to it and you'll be fine.
Also, since you have cats you'll need to keep an eye on your dust filters because all the cat hair will make it clog up faster.
I tried having  it open from start  but temps didnt drop below 50. Im omw to The company that built it so they can fix it
As others have said open to the outside is not good I am not suggesting that.  Just have to get more  airflow in there possibly, could be something else too like a bad thermal paste job.  I just lucked out when I picked this case for its looks that it has so much screened openness, It wasn't something I planned.
  • 2 weeks later...
well i returned it to get it fixed, and got it back today. they said there was too much thermal paste but they fixed that. Got it back, started it. 57C idle....
If you want it to run cooler I recommend getting another cooler and mounting it yourself. It's rather simple. Did you try installing any extra fans yet, like mentioned above?
If you need some recommendations on good air/water coolers we'd be glad to help. It doesn't sound to odd that your CPU is running around 50-60c inside of a case like that with the stock cooler. What is the temperature inside the room?
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
i mean, i dont mind since it works perfectly, just worried since its kinda hot i think.. i dont know what will cause dmg over time, what temps are ok etc.
And maybe i should get another cooling system, but i like the look of this one,(LED) etc..  and i have to apply thermalpaste? im not comfortable since i never did this before.. but ive watched and read alot on the internet.
