Very Strange Bug With Sandisk Flash Drive
SenKa
Hello, I have a 128GB Sandisk USB drive behaving very oddly. Under windows it will not mount. I get no connect tone, or anything. It's simply dead. But, under macOS Mojave it mounts perfectly and is fully functional
I have:
Tried the drive on multiple Windows PC's
Reformatted the drive to Fat32 in macOS
Nothing has worked, any ideas?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
EDIT: More Weirdness, upon a fresh format in macOS, connecting the drive to windows for the first time will yield a "The USB Device Has Failed" warning, and prompt me to plug the drive back in. I do that, and then it doesn't pick back up.
EDIT #2: Solution! As with most things, it was solved with Linux. I booted up Ubuntu and opened GParted, where I found a corrupt EFI partition. Deleted that, reformatted as FAT32, and it's now working!
Useful threads:
Total: $1891.98
