Hello everyone, I have a question!~
My specs:
CPU FX-8370
Mainboard MSI 970 Gaming
Grafic MSI R9 390X OC 8G
Ram 16GB
I have extremely low FPS in ArmA (Doesn't matter if low or ultra), but other games run perfectly fine at ultra settings. For example GTA5(Even with Redux) - Rust - The Forrest - Just Cause
I was wondering if anyone knows if I can improve my FPS in Arma 3 without actually changing any hardware? I know it's a silly question, but maybe there are some tweaks... or magic system changes I have missed?
Or is my computer just complete garbage?
Btw. I am not really good with PC's :c Help would be super appreciated!! ♥
https://linustechtips.com/topic/1014261-arma-3-low-fps/
Your processor and GPU combination is not fit for Arma 3 garbage optimization.
https://linustechtips.com/topic/1014261-arma-3-low-fps/#findComment-12130248
Yes, improving your fps in Arma III involves lowering the right individual graphic settings.
Arma III is terribly optimized so there's not gonna be much magic involved when trying to get a stable fps in the game.
Your PC is fine, just lower your expectations. Go into the graphic settings and just set everything to low and see how your fps is. Then just bump up the settings that you want to look good one at a time and take note of how much fps you lose for each setting. The more fps you lose, the lower you want to set the setting.
If you want to just know the perfect settings for your PC, let me know and I'll post them here in no time. Going to bed right now though. I still recommend you tweak the settings yourself for two reasons, one, Arma III is a game that performs dramatically different from PC to PC and two, tweaking settings is very educational.
https://linustechtips.com/topic/1014261-arma-3-low-fps/#findComment-12132941
