I'll refer you to my bio. (Actually my PC and my header are both applicable lol)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1013725-portable-case/#findComment-12125641
8 hours ago, bigmouthbob1 said:
was looking to build a portable pc, but im terrible at judging size. what would be a good case for portability sake?
Budget, location and system specs?
https://linustechtips.com/topic/1013725-portable-case/#findComment-12126617
will depend on what hardware you intend to put into the case. there are some neat Mini-ITX builds, but again sizing will be determined by hardware.
However, I just recently downgraded my computer from a full ATX to a Mini-ITX for some portability. I was able to fit all my hardware (except 1 x 3.5" HDD) in the InWin A1. The thing is a nifty semi-portable gaming computer now.
R7-1700 (@ 3.8ghz) in a MSI Mini-ITX board. 16gb of 3200mhz DDR4, a 500gb NVME drive, a 2.5" SSD and a dual fan GTX 1070.
if you want even smaller, than there are some options, but you'll have to sacrifice somewhere, usually the GPU is what adds the most space.
Quote
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." - Douglas Adams
System: R9-5950x, ASUS X570-Pro, Nvidia Geforce RTX 2070s. 32GB DDR4 @ 3200mhz.
https://linustechtips.com/topic/1013725-portable-case/#findComment-12127939
