Hello, so I just got a gtx 1080 founders edition from one of my friends, basically brand new, and I installed it a few hours ago. I am now running into “your pc ran into a problem, collecting error data........” I am running an i5 6500 with 8gb of ram. I don’t know if it’s my CPU not being able to handle it, or the ram amount, or both. I don’t know what else to do. Please help. Thank you
https://linustechtips.com/topic/1013258-help-please/
No reason why a CPU or ram would not be able to 'handle' that GPU.
https://linustechtips.com/topic/1013258-help-please/#findComment-12122075
Do you have any more info on that BSOD? Like the error code or the message that it says?
Also, it's not a bottleneck in anyway. You're good in that department.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/1013258-help-please/#findComment-12122139
13 hours ago, narrdarr said:
i have an i5 -6500 with 16gb ram, gtx 1080 ftw on a z170 mobo. it handles just fine. does event viewer show anything?
13 hours ago, UnspeC5d said:
You gotta update the drivers, does the PC straight up crash when it opens?
Yeah my PC wont even display anything. I turn it on, and nothing happens.
https://linustechtips.com/topic/1013258-help-please/#findComment-12123945
I can’t even get an error code anymore. Now it just won’t display anything, or when it does, my pre boot menu just freezes.
https://linustechtips.com/topic/1013258-help-please/#findComment-12123948
1 minute ago, narrdarr said:
don't know what mobo you have. but, can you try a different pcie slot.
also it could be your psu
I have the msi csm h100m pro vhl, and I’ve tried all the pci-e slots I got. I now figured out there is a red light above my ram sticks, and I have no idea what that means or why it’s on. I’ve never noticed it before either.
https://linustechtips.com/topic/1013258-help-please/#findComment-12123967
On 12/27/2018 at 3:01 PM, narrdarr said:
@hoiv there are three leds there they are labled too. cpu, dram, vga. which one is lit up?
I got it all fixed,was a pain and very annoying but ended up fixing it. Turned out it was the DRAM light. Took out a RAM stick, and my HDD, gave it a boot, ran the bios and everything, then shut it down, put everything back in and I was good.
https://linustechtips.com/topic/1013258-help-please/#findComment-12128682
