What cooler should i buy for a better temperature?
Solved by FilipSebik,
Just now, GabrielLP14 said:Thanks, even a 360mm cooler wouldn't be better?
And honestly i doubt this AKASA CPU cooler is better than my Corsair hahah
No it wouldn't make a noticeable difference and I doubt the AKASA one would be better than your AIO too, but its the best Air alternative that you can get right now. If you think its worth trying it then do it and if you are not satisfied then you can return it if it they accept returns
