G'Day,
I was just wondering if anyone here has a meshify c and tried the coloured panel and whether it is worth it or just spraying the normal one?
Good Luck,
Sam
PC SPECIFICATIONS BELOW
APOLLO_ - Ryzen 2700x | Asus Crosshair VI | No RAM atm | ATI Radeon™ HD 5450 | Corsair H115i | Aercool P7 750w | Corsair NX500 400GB + Seagate Firecuda 2TB |
ALPINE PASS - Just a Dell 7447
https://linustechtips.com/topic/1010252-meshify-c-coloured-front-panels/
5 minutes ago, RUPPLE said:
G'Day,
To properly paint the black ones, I'd recommend taking the foam filter out which can be a little bit of a pain.
I'd probably only suggest DIY'ing it if you dont like the color options available.
Thanks I was just wondering if anyone here had done either method.
Good Luck,
Sam
