Bare Minimum Front Panel I/O configuration
Bare Minimum I/O
15 members have voted
  1. 1. USB 1.0
    • Excuse me????
      15
    • 1+ (GTFO this forum!!!! jk XD)
  2. 2. USB 2.0
    • Not Needed, only have 3.0's, even if it makes the case more expensive
      6
    • 2
      9
    • 4 (Please put reasoning/use case below)
  3. 3. USB 3.0
    • 1
      1
    • 2
      9
    • 3+ (Please put reasoning/use case below)
      5
  4. 4. Type C
    • Not needed on cheap cases, but anything above lets say $80 should have at least 1, if not more
      9
    • 1
      6
    • 2
      2
      1
  5. 5. Type C Thunderbolt
    • More relevant to laptops with limited I/O
      11
    • 1
      4
    • 2
      3
      1
  6. 6. Headphone Jacks
    • Yes
      11
    • I'm an Apple Fan... jk. I don't really need a headphone jack on the front/ I only use speakers
      4
  7. 7. SD
    • Not Needed
      10
    • SD
      6
    • MicroSD
      2
  8. 8. Other
    • e-SATA
      2
    • FireWire
      1
    • CF
      1
    • MS
      1
    • Fan Controls/dials
      4
    • Touchscreen Panel (fan/temp display)
      2
    • None of the above
      10
Keeping in mind that a traditional low end mobo has maybe 2 usb 3's and a few 2's and a medium end board will typically have 2-4 3's with a type c or two, plus a couple of 2.0's, What kind of Front Panel I/O do you think is BARE MINIMUM for any case, small or large?
I know it's a long poll, but bare with me, and honest answers please.
Edit: Remember I'm asking for Bare Minimum. If a case doesn't have X, regardless of other features, I'm not getting it period
Insanity is not the absence of sanity, but the willingness to ignore it for a purpose. Chaos is the result of this choice. I relish in both.
https://linustechtips.com/topic/1009972-bare-minimum-front-panel-io-configuration/
Best front I/O configuration IMO:
- Two USB 3.0 Type-A ports
- Two USB 2.0 Type-A ports
- One USB Type-C port
- Headphone jack(s)
- SD card slot
BTW, for some reason the last part of the survey (9. Other) is mandatory, it shouldn't be.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
all front I/O you really need is a pair of USB ports, front audio is a nice add-on too.
but honestly, beyond that..
- type c : put that stuff on the back.
- thunderbolt: because we all want to plug GPU docks in the front I/O of our desktops.
- built in SD card readers are a curse, once they go bad or outdated all they are is in the way.
- all the stuff under 9 is IMO a waste of space on the front of the case.
2 USB 2.0
2 USB 3.0
1 USB-C (thunderbolt would be a plus, but not required)
SD card reader (my case has one and it might seem like a silly thing but if you switch to a case that doesn't have one it's REALLY ANNOYING O_O)
Fan controls are nice but not a requirement.
Why 2 usb 2.0 and 2 usb 3.0
1) not every usb 2.0 device works fine in a usb 3.0 port.
2) for stuff that just needs some juice any usb port is fine.
3) not every motherboard has 2 usb 3.0 header connectors, but there is always 1 and usually there are plenty of usb 2.0 headers available.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
I don't see how USB 2.0 ports are needed, since USB 3.0 port is backwards compatible with USB 2.0.
The USB 3.0 port spec has two sets of pins; one for USB 3.0, and another for USB 2/1.
Image result for usb 3.0 pinout
THAT SAID, this is if motherboard manufacturers are willing to provide more USB 3.x headers on the motherboard.
I'm all for USB 3.0 altogether.
USB Type-C, with or without Thunderbolt support -- Thunderbolt support preferred.
SD and microSD card slot would also be a nice plus.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
About type-C, you have SSD's that use USB-C so it's nice to be able to connect those on the front instead of taking a dive into the back.
SD card readers, how can they get outdated?
If you mean speed wise, they use usb 2.0, it's not insanely fast, but 25MB/s read-write is more than enough to max out most SD/microsd cards.
And an SD reader with usb 3.0 would increase the price quite a lot because they aren't exactly cheap, they would require a usb 3.0 header which is again not always available (most motherboards only have 1 and connecting both USB 3.0 and an SD reader to a usb 3.0 port would probably require a sort of hub increasing the price even further)
And it's not like SD is going anywhere soon, they are everywhere and there is no replacement in sight.
Interesting point... I didn't think about header availability. I'm not getting a clear answer by asking google the number of ports per header, but looking at available front panel io hubs, it seems to be capped at 4. If anyone knows this for a fact, please let me know. Given that, if we assume 2-4 of each type, you would need a usb 3.0 header and a usb 2.0 header. Can someone tell me if most motherboards have one of each header or only one or the other? If it's only one or the other, then I'll change the poll to reflect realistic options
I didnt read "bare minimum", thought this was preference and chose 4 3.0's with a type C with no headphone jack (Most implementations arent shielded so I was getting a lot of static in my "higher end" headphones)
But For bare minimum I/O for all cases, 2 usb 2.0's, one USB 3.0 (preferably 2) and front audio. But I'm talking bare minimum in the sense that all cases should come with it whether theyre recommended or not. Recommended cases should now have at least 2 3.0 ports
1 header = 2 ports.
It's actually very clear for USB 2.0 if you look at the pin lay-out.
Most motherboards have 1 usb 3.0 header and 2 usb 2.0 headers (that's at least what i usually see)
The reason I include that is purely cost. I don't know the manufacturing costs myself, but I would assume it to be more expensive to get more 3.0's in a case than to have 1 or 2 then toss some cheap 2's in for extra connectivity
I hadn't thought about that. And I have a feeling more portable ssds with type c will show up in the market
their driver support is garbage, and i prefer my case not to get obsolete because a new version of windows bricked the drivers.
...How did you manage to brick the OS with SD reader drivers?
Like, how? Aren't there generic drivers that just work?
I have a silencio 550 and it's 6 years old and windows 10 just works, i didn't even think about drivers for the SD reader, it just worked.
There were no drivers with the case so I'm just, confused, like how?
The Samsung T5 is a very popluair SSD that uses USB-C and they existed for a few years now, but they are indeed getting more common which is nice.
so you don't find a type c bare minimum? do you often use type c?
7 minutes ago, samcool55 said:
1 header = 2 ports.
Interesting, what about products like these?
https://www.amazon.com/Tendak-4-Ports-Metal-Connector-Adapter/dp/B00Q6XFAFU/ref=sr_1_14?s=electronics&amp;ie=UTF8&amp;qid=1545166445&amp;sr=1-14&amp;keywords=front+panel+usb+hub
I was gonna say they might be lying about the capabilities of half the ports, but they still only use 1 header, so i'm confused.
Thanks for the mobo header count clarification.
There's a controller on them so it's a hub, not a straight pass-through which would be the case if it was just 2 ports.
Also only 1 port so only half of the connector is actually used.
There is a reason why it usually looks like there are 2 wires coming out of the connector.
USB headers (2 and 3) are basically just pass-throughs, there is no logic in them.
Not yet.
Type C isnt common enough yet for it to be warranted as a bare minimum. It for sure is future thinking to have one on your case (which is why I'm considering them for my next case) but as a CASE enthusiast my prices are a bit higher than the average consumer looking at their next PC. Plus I'm also looking at 3.1 gen 2, not gen 1. Gen 1 may as well jsut be a regular Type A 3.0, not much point otherwise.
os bricks drivers, not drivers brick os.
and yes, they're generic drivers, and that's the issue..
someone makes the drivers
someone makes the hardware
someone puts the hardware in a product
someone makes the updates for the OS those drivers run on
now, suddenly it stops working.. who needs to pony up the manpower to fix it?
Isn't the point of generic drivers that they work regardless what hardware you have so it always work?
What you describe doesn't really sound like generic anymore.
In the end the only thing in that chain that needs a driver is the controller that allows the SD card to talk to a system via USB.
If generic doesn't work, what about a driver specifically for that controller?
And what case caused the problem?
the problem with generic, is that generally it is not maintained. if it is a usb box i'll just toss it in the recycling bin and buy a new one. if it's built into my case.. i'm stuck with it.
and as for a driver for a specific controller, the generic driver, because the controller is made for the generic driver, insert huge loop here.
as for what caused the problem.. the card reader was about 6 years old, and the latest cumulative update for windows 10 (which.. windows 10 didnt even exist when the card reader was made) made something go wrong with the drivers where it wouldnt detect cards anymore.
