So i just recently ordered everything for my first computer build. i was wondering if you guys could check it out and think if i will have any problems with this build.
-AMD Ryzen 3 2200G
-ASRock B450M-HDV
-G.Skill Aegis 16GB (2x 8GB) DDR4-2133
-Western Digital AV-GP 500GB 3.5" 5400RPM
-ASRock Radeon RX 560 4GB
-Rosewill FBM-X1 Micro-ATX Mini Tower
-Apevia 450W ATX
https://linustechtips.com/topic/1009879-christmas-first-build/
the apevia PSU is rubbish, get a CX450/M instead. also, get 8gb for now and use the money for a better GPU.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094582
I already bought all the components from the list. Any difference between CX and Apevia? I just went with lowest price their was.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094595
A bad psu can burn out earlier and has a chance of damaging your system if you aren't lucky
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094606
read this article on cheap a review of a cheap psu
https://www.tomshardware.com/reviews/low-cost-psu-pc-power-supply,2862-1.html
i dont think your psu is as bad as those but it is still worth it to consider whether you want to put it into your system
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094627
That 5.4k rpm hdd will feel kinda sluggish, heads up. It wont really hinder game performance too much but as someone who used to use one  it'lll take a hot sec to do anything. I'd say drop the extra 8Gb of ram too, 16gb of ram with those specs makes no sense. Instead up the hdd to 7200rpm and get a 240-256gb ssd to boot on
Edit: If you need the two sticks for mem bandwidth on the ryzen chip Id opt for a 2x4 config, to be fully clear though I dunno how much the extra bandwidth will do since you arent using the apu so if it doesnt really effect the cpu that badly just go with the 1x8gb and save room for upgrading
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094634
There's quite a bit I'd change:
  • Try and save a little more for an RX570. It's significantly better, and they've been on sale quite a bit lately, as has the RX580.
  • Ryzen needs faster RAM. Try and get something at least 2800mhz, though 3200mhz would be more ideal.
  • A 5400RPM hard drive is going to be painfully slow.
  • Get a better PSU.
Why did you wait until after you'd ordered it to ask for advice? That doesn't make much sense.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094679
  • Get a better PSU.
impatient and also Christmas is coming up.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094707
Well, I guess you reap what you sow. Not waiting has left you with some serious pitfalls.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12094851
1 minute ago, butsagington811 said:
Which components here impact my build the most?
Memory speed, HDD speed. The graphics card is probably pretty awful too, I'd compare it to the integrated graphics; if it's not too far off, just run that instead and save for something better. Especially since they're supposed to release new stuff at CES. The PSU is dangerous and could kill everything else.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12095121
ill buy a new PSU in a while then with my own money. most of the components were brought because i got christmas money.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12095136
Buy some parts like these?
-G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory
-Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12095152
NEVER. EVER.
EVER EVER EVER
Skimp on a power supply.
Dubs are better than subs
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12096768
vastly better quality than the apevia. don't touch it and return it straight to the seller, Apevia PSUs are generally closer to explosives than anything else.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12096778
Yeah, those are good.
https://linustechtips.com/topic/1009879-christmas-first-build/#findComment-12098353
