I need yall help. im upgrading but on a very limited amount of money this christmas.
things I need:
ram
hdd
gpu
now i need help should i spend the money on my ram to buy a better gpu or should i balance them all 3?
which one is better? going all on a gpu and hdd
or
gpu,hdd,ram
https://linustechtips.com/topic/1008790-proper-advice/
You left out some crucial details like what parts you currently have, how much you want to spend, etc.
https://linustechtips.com/topic/1008790-proper-advice/#findComment-12085154
I'm guessing the HDD is necessary. Between ram and gpu, it depends largely on your current specs and what you use the pc for. If what you do is mostly cpu intensive or something, to hell with the gpu cause ram will be more effective. If you do mostly gaming and have a decent amount of ram in your system, then screw the ram and use it for a gpu.
print "Hello World!" ("Hello World!")
https://linustechtips.com/topic/1008790-proper-advice/#findComment-12085161
1 minute ago, AllaboutBudget said:
im sorry for the short details
here are my specs
i5 2400
200gb hdd
4gb ram
i do play games most of the time.
and im planning to play triple A games
Well, you'll see much improvement if you use an SSD instead of an HDD. You are a bit short on ram, but at the same time, a powerful gpu will be bottlenecked by the cpu
https://linustechtips.com/topic/1008790-proper-advice/#findComment-12085167
3 minutes ago, AllaboutBudget said:
what exactly is your budget.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1008790-proper-advice/#findComment-12085168
Well since you didn't give a price limit I would suggest a 9900K and titan RTX along with 128GB of ram and 20 NVME SSDs.
https://linustechtips.com/topic/1008790-proper-advice/#findComment-12085186
